Mimaki CG-60ST USB-Serial connectivity issues
Dan77
Hi,
I have a Mimaki CG-60 ST plotter and have tried connecting it to both PC (using XP SP2 run on bootcamp) and Mac OS X 10.5.8 using a serial to 34mm Expresscard without success.
I've entered 'device manager' and 'printers and faxes' in XP and assigned the plotter to COM 2 with no results.. I've also set Finecut 7 to use COM 2. The 'printer' still appears offline. I'm also using the Mimaki Driver 1.2 downloaded from their webpage
Im running Illustrator CS3 and Finecut 7 and have received the following error messages when attempting to plot using Finecut 7:
"Cannot send data to plotter. Check whether the cable is connected correctly".
"Non-Mimaki plotter is connected. Finecut is able to output to mimaki plotter".
"An error has occurred. Error number 1".
Unfortunately this plotter only has a RS-232C DB25 serial and parallel output, so I'm wondering how other people might have overcome this problem using a USB - Serial adapter or otherwise, and what if any version of FineCut they have managed to get working..
Thanks in advance.. Any info, advice or suggestions would be greatly appreciated
:) Dan
nashvillesigns
Making America great, one sign at a time.
Any luck? i tried this with a 130 cutter. using one computer with a USB and the other with a DB25/usb plug. it worked
Ian Stewart-Koster
Older Greyer Brushie
Bu default, Com1 serial is setup in Corel.
You need to go into Corel Finecut menu near the plotter blade icons, and find the setup menu. Tell it USB. (not com1)
