mimaki cj30 error
patraulea
mimaki ucjv300-160,mimaki cjv30
hi
i have vertical lines at aprox 40cm and 80cm on an 120 cm job..
if i move the job with 5 cm to the right, the lines are also moving 5cm to the right.
That's either going to be a dirty or damaged encoder strip or an electrical issue with the head/cables. I could clean the encoder strip first as that's the most likely culprit.
