Hello,
I'm fairly new to wide format printing. I purchased a Mimaki CJV150-75 in '22 to be able to print marketing materials in-house (stickers, banners, posters, etc). I don't print every day, but I do at a minimum run test prints everyday to make sure everything is in working order. About a month ago we had a weird power issue where our utility was sending high and low voltage into our building because of a transformer failure. One side of the panel was only getting 41V and the other was 120V. During this period the printer was only on the auto cleaning cycle for a half the day before we figured out the voltage coming into our building was messed up. Our printer has always been connected with a surge protector. Since this day I haven't been able to get the printer back to working order. I've run over-night nozzle washes and recovered most nozzles but it has reached a point where no matter what I do nothing improves. This is what the test prints look like:
I've tried printing some solid CMYK blocks to see if the nozzles would clear up, but the results were fuzzy colors with a bunch of what looks like overspray.
The service tech I've worked with says the printer needs a board replaced, or the head is bad. Are there any more things I can try before jumping in and spending $4-5K to get the machine running again? The capping station is clean. I can see waste ink being pulled through the lines during cleaning cycles. I'd like to do as much of the trouble shooting my self to keep the service call time down if I need to go that route. Any suggestions or advice would be greatly appreciated.
