Mimaki CJV30 Cutting Black Vinyl - With no Registered Marks?
thetomsid1
Hello,
So I have a sign writing job to do with black vinyl.
However is there a way to cut black vinyl on the mimaki Cjv30 machine without registered marks?
I say without registered marks, because the registered marks are printed in black and will not show up on the black vinyl.
Any help is appreciated, thanks.
If you have illustrator or Corel draw you can use the Finecut plug-in that should have come with your printer. It allows you to cut directly from those programs to the printer as if it were just a cutter.
myront
Dammit, make it faster!!
If you have to use reg marks they need to fall outside the cut area. i.e. if your cut is 10in then your reg marks should be set at 11in. If you need to cut in an area that's black as stated above you don't use reg marks.
