Mimaki JFX200-2531 flatbed,
woody1512
Good morning all, I have an issue where my printer is running 1.5mm over size on the feed direction only. Normally I wouldn't complain about such a small amount and with the job having 10mm bleed on each edge, however it is causing issues with our panel joins not aligning by 1.5mm (Pain when running through the text or images). The panels are Kongsberg cut after printing. we have eliminated the Kongsberg as the issue as well as file setup being an issue.
Does anyone have any idea if there is a way of checking the scaling on the print on the flatbed?
Smoke_Jaguar
Can put all issues in one thread for making it easier to track. But anyways, have you tried running media size compensation on the quality tab?
Also, there's a dedicated Mimaki section on the forum where your post is more likely to be seen by we Mimaki nerds.
