Back with round 2 of printer gremlins, this time it is the white and clear subtank draining all the ink when the machine goes into sleep mode usually a minuet or so after the cycle ends. The color subtanks seems to be unaffected and stay filled.
I have run an air purge and ran the negative and positive pressure settings. The negative sits pretty solid once set with the positive a little more jumpy. Before this project was handed over to me the air filters above the subtanks had been replaced and there is a small bit of the tubing that doesn't match quite the same as the others and I'm wondering if there is a chance that it's letting amount of air to leak thorough.
I guess my question is two parts 1) is there anything else I should look at? 2) recommendation on hose type for air systems?
Thanks in advance for any time and advice that can be offered.
