Eirikprint
Hello, our UJF 7151 Plus II started showing "Error 404 y-origin" yesterday, and today it showed "Error 50a y-origin". After I restarted the machine today, the error was gone - and I did the following test:
1. Execute and confirm [#TEST]->[SENSOR TEST] - >[Y-ORG].(Confirm that the ON/OFF display is switched by moving the carriage left and right.) 2. [Execute [#TEST]->[CHECK ENCODER].
Nothing noteworthy happened during the test, everything seems fine - and this is what was read from the "Check Encoder" settings:
M: 2.0mm - 400puls
E: 43.5mm - 2. 600puls
We started hearing a clapping sound from the carriage yesterday during printing, and it doesn't start until it is halfway into a print or so. I took a video to show. What could be causing this?
Update: I just did maintenance > carriage out and cleaned up, and I decided to film the carriage going back home just in case anything happened. Now we are getting this error again:
Update again - we found out what the slamming noise is after further watching the video. If you look in 0.25 speed, you can see and hear that the mechanism for the tray is being hit by the carriage.
I am not sure, but this isn't supposed to be hit during printing right? What is the name of this tray/mechanism anyway?
M: 2.0mm - 400puls
