Ghost Prophet
This is on the Falcon Outdoor 1
Alright I recently had a cross contamination issue due to the new capping station pads swelling up and touching the print heads... Fixed that by removing one pad layer and sucking all the contaminated ink out of the Yellow damper. Finally I had yellow again, which meant I could now print red...
Red was printing great for a while, then turned pink, so I shut it down and did a nozzle check and neither Yellow or Magenta are firing at all... However there is ink in all the dampers... The fuck is going on here?! Bad print head or loose ribbon cable?
I'm about to pull it apart and do some intense checking but meanwhile tips would be appreciated. ^_^
