Mounting a 40lb sign on Tile Backsplash with Standoffs
AllStarNow
Has anyone attempted something like this before? The sign is 78" x 23.5" two layers of 1/8" aluminum and weighs 40 lbs. It has 6 predrilled holes and the client is wanting to mount with 1" standoffs on a tile backsplash wall. I'm thinking it's drywall behind the tile, I'm not sure yet as I'm going to the site to meet with the client tomorrow. Has anyone attempted something like this? My fear is that the shear weight might crack a tile (maybe not immediately) even if we find a decent enough anchor. I have some thin rubber grommets I can use on the backside of the metal standoff that might help, other than that some toggle bolt anchors.
Splash0321
Professional Amateur
Are we talking small mosaic tiles or are they 4x4 or larger? That’ll make a difference. Larger tiles would be less likely to break during and after installation. Smaller mosaic tiles just don’t have a lot of surface area to help carry much weight.
Each standoff will be holding about 7 lbs. If we’re not talking about smaller tiles you’ll probably be okay.
Moze
Precision Sign Services
1/2" diamond core bit, 3/16" Toggler Snap Toggles anchors, silicone washers between the tile and standoffs and you'll be fine. That's not that much weight/pressure once it's spread out between the 6 standoffs.
jfiscus
Rap Master
What about using "false" standoffs? Where you would actually just VHB the sign to the tiles (with an appropriately thick spacer (like 1/2" PVC) behind it, and put the standoffs in place like they were installed? Would save drilling permanent holes into tiles. IDK, just thinking.
