Signed Out
Alright this has happened a few times now and I figure why not ask to see if we are doing something wrong.  While mounting a print on a 8'x2' piece of polymetal (acm) we line up the print check measurements make sure everything is square, then lay down some 4" mask on the leading edge to stop any streching or wrinkles and lay down the first 4" and double check to make sure everything still lines up, next we set the acm in the laminator square and in the middle of the rollers and lower jaw, then peel back the backing paper and begin laminating. After laminating the leading edge is good but the back edge has somehow moved about a 1/4". This only seems to happen on long and narrow mounts. Does anyone know why this is happening or how to fix/stop this?
