Multiple Jobs on HP FB750
Joshua Barnes
Is it possible to print a document with multiple pages on separate foam boards, or do I have to break the job up? I know how to do multiple copies of a single image, but I'm not sure if I'm missing something.
flyplainsdrifta
either way, that video really clearly describes the n-up process. if they are all the same dimensions just evenly space your pins with a 1" spacer. its essentially the same process
Joshua Barnes
Just watched the video. Where the "print multiple images n-up" button is, we have a button for 2 sided printing. Can you change that menu option?
flyplainsdrifta
pre load the media. don't do the live load from the print menu. start at the media menu. then load your sheets. once loaded you should see the option appear. the n-up option only appears once you get media into the machine.
Joshua Barnes
Got it. I missed that the first time I loaded multiple boards. Thanks!
