Multiple print laminate cut files
CentralSigns
Can you have multiple cut lam print files all cut off at the same time. Will Versaworks know which is which when they are scanned back in prior to cutting.
S
scarface
Guest
All you need to do is keep the files in the A or B window and your good. If im doing a big bulk i'll split it in even amounts so it doesn't matter as much.
Bigdawg
Just Me
If you mean ganging them in Versaworks - and using one set of Print/Cut Alignment marks then yes -you can do them all at one time if you printed them that way.
You can't queue up a bunch of prints though and then send them to cut unless you have them in the same order that they are on the sheet. And even then I've found it's better to manually realign on each set of marks.
CentralSigns
Thanks guys for the answers. I had printed one in Que A and was waiting for it to lam(gasout) and was hoping I could start another file in same prompt. But if I have to use B then I'll have to wait just in case I need to print in the meantime. Hadn't thought of doing both jobs at same time and I guess that's what screwed me up.
GVP
If you use VW's nesting, you can rip and print and just leave the nested job in the queue. You can carry on with other jobs in the same queue and come back to your nested job when you're ready to contour cut.
