Logic is telling me I would attach this to the end of the line where the ink bags go, to see if I’m getting get fit on the capping station, is that correct?
I am wondering if on a Mutoh, that would be the 2 hoses below the maint station.i am not looking at a mutoh,
but
on our rolands,there are hoses off the captops (the piece that comes up to meet the head) and you remove the hose at the bottom where it goes to a pump, and pull ink through until it fills the damper, passes through the head, then the captop and fills the syringe .
rinse the syringe, if you prefer, and do the next color
That's correct. You just have to clog one of the tubes or pull from both at the same time or else you'll just pull air.I am wondering if on a Mutoh, that would be the 2 hoses below the maint station.
I just tested it with a vacuum pump. and I can hear air leaking from what sounds like the where the captop & print head meet, I shouldn't hear anything if there is proper sealing, correct?That's correct. You just have to clog one of the tubes or pull from both at the same time or else you'll just pull air.
I connected a vacuum pump to the 2 hoses and tested the seal, I could definitely hear air coming from what sounded like the capping station...ssims21
Here is the location of the 2 tubes below the Maintenance Station on the VJ-1204. You will need to remove the Waste bin and then you can see the 2 tubes. It's a pain to get large hands in this area, but it is doable.
