Mutoh 1204 valuejet printhead/ink lines problem
zevlove
Greetings community!
Was wondering if anyone can help me with an issue im having with my printer that has been sitting for over a year.
Ive replaced the maintenance station just to start fresh.
Ive checked the nozzles, and have done multiple cleanings...its weird because I see ink in the lines but I dont see any of the ink moving through any of the lines when I run a nozzle check or cleaning, which is why im confused. :help
If the printhead is not clogged and if the maintenance station is working properly I should be able to see ink moving through the lines, right?
Is there anything else I should do or check before I replace the printhead?
Thank you for any suggestions.
