Need Help Mutoh 1614 from OCE 9160
FatCat
If I recall, there was a thread on this a few years ago, the simple answer is no.
It can be done - but it requires you to buy Mutoh brand main boards to do it and swap out, you can't just flash the boards in that printer back to Mutoh code/programming - so probably not worth the cost or hassle. Also, there was an issue due to the ink cards being different as well.... If you search back the thread should still be there...
Umca
Why you want to convert?
It is not a problem to comvert from Oce to Mutoh. Just need to reset company code in printer's memory. Special software should be used for it.
Plottermike
Thx for your answer.
I'll need a Mutoh to afterwards unlock smartcards.
I have msa and Mea Here.
Can you Tell me how it Works?
Actually Using 3rd Party inks with oce smartcards
Umca
There is not so easy to explain. I just saw technician did it with my friend's printer.
Please contact him if you want. Will send PM.
