Mutoh 1624x will not turn on
Darion Judd
Hello everyone and happy 4th!
I just replaced all four dampers in my 1624x as well as my maintenance station. When I go to turn the machine on it acts like it’s going to fire up but as soon as it reaches the “version 3.0” screen it shuts down completely. Does anyone know what is causing this to happen? Any advice would be appreciated!
Thank you,
Darion
Pitzu
After replacing the maintenance station did you connect all the cables? One for the motor and one for the encoder?
Pitzu
Could be some ink spilled on the printhead when you changed the dampers. If the ink gets on the printhead cable connector, it can cause short circuit.
Just throwing ideas :)
h82loose
Did you unplug and discharge the machine before working on it?
Sent from my ONEPLUS A5010 using Tapatalk
