Hi good day everyone!
I am having a problem with my machine. It's printing long jobs in the wrong size and is always an 1" or 1.5" shorter than the correct size. Short jobs usually print the correct size but it is the log jobs that prints out wrong.
I have tried doing a page feed adjustment but to no avail.
I do the initial print for 500 mm, then do the initial change until I get the correct measurements and do a confirm print to "confirm" that the feed length is correct and measures 500 mm. But after all this, it still prints jobs in the wrong size! The weird thing is right after I do the PF adjust and ensure that the confirm print is correct, I do the initial change to see if it measures 500 mm and it doesn't. Shouldn't it measure 500 mm if I just calibrated it?
I am using Sai FlexiSIGN & PRINT Mutoh Edition 12 and there is a feature "Output Size Compensation". I have this feature turned off. Does anyone know if it will clash with the PF adjustment if I turn this feature on and continue to print jobs in the wrong size? or will it override the PF adjustment on the machine?
Cheers,
PhuKing.
Cheers,
PhuKing.
