Click to Support Signs101 ...
Sounds like your pump is nearing the end of it's service life.
On my 1304 I can check it under
Menu1> Setup> Set 22> Life Times> Pump:
Shows E*****F
I think when you run out of * it is time for a new pump.
Shows E*****F
Hi I have a rj 900 pro printer with 162 err p life
But I try resetting with up down and right arrow and go to parameters and initialize and go to pump but when start normally it still bring error.
I change the full maintenance assembly. Any ideas?
