Racegrafix
Old printhead gave this error. Replaced head, tried many cleanings, couldnt get two channels to work on new printhead. Replaced cables. Error 85. replaced cables again error 85.
The cables are horrible. The official rating is that they can be installed 3 times before failing.Thats very good. With a little luck no transistors death. Replace the fuses with the same ones, and be sure cables are perfectly aligned with the pins this time. Be sure with the position in the printhead too... They are not swappable. Be extremely carefull with those cables... Are the worst I ever seen on this kind of machines and is very easy to not align them correcly in the pins.
Ive already replaced dampers, cap top, pump, printhead, cartridges, fuses, cables, and primed the dampers, tried pulling ink manually, etc.Charge the printhead manually with ink (suck slowly with a siringe from both tubes with an Y connector until you have some ml in the syringe) and try to print without doing a cleaning after that. If it prints absolutely nothing... The normal cause is those 8 big transistors in the black cooler are fried... Its very typical. Try to replace all 8 (its not easy but you dont loose but some dollars and some time). Be carefull because there are 2 kind of transistors (a1746 and c4131 usually on rolands and mutohs) If it doesnt work, i suggest changing both, motherboard and printhead at the same time. I had that problem in a 1204 and the old printhead keeped to blow the fuses (and thanks it was only the fuses) until I replaced it. If you want to test the printhead you can buy a cheap Epson 4880 or r2400 (and swapping the printhead cap top with a ecosolvent one)... I tell you because dx5 now are expensive. I only did that once with a 4880 and printhead lasted like 9 months (but it was a really old 4880 we bought on earlys 2000)
At least you learn one thing... Always you mess with that cables, replace them. Every time you replace printhead, replace those devil cables
In my experience the DX5/DX7 aftermarket cap tops tend to be good quality as long as they look similar to the OEM ones. The ones that have plastic screens in them instead of metal tend to be the worst. But compared to other aftermarket cap tops most of them are legit.I bought another cap top to try, non oem. I know everyone hates non oem, but I am not a fan of oem parts that dont work either. I bought the oem and it hasnt printed a single thing and Im pretty sure its bad. It absolutely wont seal to pull suction.
