Mutoh Falcon 2.....Using more Magenta & Yellow than it should be??
onlyjames
The World Is Never Enough
Hi all, I was hoping to get a few opinions on something.....
My mutoh falcon 2 is going through MUCH more magenta & yellow than black/cyan. I notice also that its going through more magenta than yellow....at an unreasonable rate. Im changing the magenta 3-4 times before I change black or cyan once.
Is this normal, or is this a sign of a possible problem?
I also notice that the magenta and yellow seem to leave a lot of extra ink around the print head wipers....like its oozing down?
Does anyone have any thoughts on this...or has anyone experienced a similar problem?
randya
While it is possible you may have some issue with the ink delivery system for these two colors, these are the most used inks typically, of course, depending on what you are printing.
