Rob_maxgrafix
I recently was "given" a Mutoh Falcon Outdoor 48 printer. It came from a personal friends business, has no use for it anymore. He told me "It has been sitting for 6 months, and it was printing fine then. it will absolutely need new lines, and maybe a few other parts, I don't have the time to tinker with it, if you can fix it, you can have it." Im not just taking his word for it, I've seen it running before.
Ok, sounds like a good deal to me, It will be a step up from my colorcamm, lol. Ive ordered and received the overhaul kit. New heads, dampers, capping station, pump, etc . . .
Now here's the issue. when I turn it on, I'm receiving the Y encoder error message. I've searched the forums and tried the suggestions (belt tension, clean encoder strip, move the head to another location so see if it returns) but my situation is different than the others with the same problem because the carriage DOES move, about 8 inches or so to the right, then the error message.
I spoke directly with a customer service rep at mutoh and he said that in all likelihood the actual sensor is bad, considering that the y motor turns and moves the carriage, and the encoder strip is clean. BUT they dont have any that I could buy.
I found one website that sells that particular sensor individually:
http://www.digiprint-supplies.com/encoder-reader-incl-cable-my-41465.html
Do you guys think I'm heading in the right direction? I would really be ecstatic if I could get this thing working and be able to have it for only the price of the refurbishment.
