pastrosigns
Hello everyone. I have a falcon outdoor jr and I can only get the cyk to print and no magenta. I opened up the machine (after running it through several power washings to no avail) and found no ink in the magenta line. The magenta cartridge is new and full. I used a syringe to pull ink through the damper but as soon as I remove the syringe, I can watch the ink bleed back to the cartridge. I also pulled the cartridge after pulling ink to the damper again and the ink still bled back out of the needle that goes in the cartridge.
I suspect that there is supposed to be some sort of check valve near the cartridge but I cant find anything that tells me so.
Any Help is appreciated. Thanks
