luggnut
i thought i had this thing figured out.. wrong. i replaced maintenance station and all dampers and i get a good seal if i want to pull ink with a syringe. the first time i pulled ink i could see the dampers filling up so i knew i had a good vaccum seal. but now i can not get all the colors to fire!
i'll clean and get some back and loose others then i will clean again and get some of the lost ones back and then loose some of the others...?? if i pull ink with the syringe i get most nozzles firing but bad cross contamination issues..
i need some advice..
also i read about bad ink cartridges causing people issues... is this the issue they were talking about?
