Mutoh Ink Startup
midnightmadman
If the ink was removed and put back in and the lines have dead air spaces, is there an option to get the lines all primmed back up with ink-- like a first install?
MacDaddy
yup, or you can do this:
Enter diagnostic mode (Cleaning, Menu and Shift while Powering On)
Machine will display DIAG EXAM
Press the Menu button once
Machine will display DIAG ADJST
Press the Enter button once
Machine will check material size then display:
ADJST HOME
Press Enter once
Machine will adjust it's home position then display a number
Press Enter to accept the home position then press Menu once
Machine will display ADJST HEAD RANK
Press Enter all the way through the head rank menu (about 6 times)
Then the machine will display FILL BK and COLOR
Press ENTER
Machine may prompt you to change the waste tank if so change it
If not it will proceed with the fill for about 10 minutes.
When ADJST CHK NOZZLES is displayed the fill is finished.
