Here's the problem. I replaced the heads, pump and capping station. Just before doing so, I printed a test pattern as a record of how bad the heads were. The black and color heads printed, but not all nozzles.
So I replaced everything, waited 30 minutes after the fill as per the instructions, and did a test print. Color was fine, but no black (K). Checked everything; it looked fine, so tried another test print. Still no black. So I sent my test file (the alphabet with every letter a different CMYK and RGB color). The file printed fine, including the A (which is set as K, as well as BCD (CMY) and all the rest). So I tried some more test files with different colors, just K, etc and it works great.
Now, I tried to print a contour cut project, and no align marks. Yet the black image printed fine, and the printer went through the motions of printing the align marks.
So for some reason the printer will not print internal commands for black (K), or system-generated align marks, but no problems from a file. Strange, huh?
I'm making my own align marks and it's working fine, but it adds a few minutes to each job, and I need to send separate cut and print files, which I never had to do before.
So, just wondering if anyone had any thoughts? Maybe I changed a setting in the Diags or something?
Thanks for taking the time to read through this, and any comments you may have.
