Mutoh KONA
msenjur
hello!
im doing some print&cut panels. it has 84 A5 decals with some cutlines in them. it is 2m long panel. 20pcs of them
im having troubles with cutter, because it stops cutting in the middle of job. Usually it stops on same last shape, which isnt cut completly. It should cut yet 2cm of line. And than laser should go start reading for next segment of panel. But is just stops there and nothing happens. Then i turn it off, turn on and i manually select next segment and it cuts ok till that same last shape, where it stopps again.
i tried deselect that last shape, than it stops cutting on shape before that.
Line of that shape is normal cut line. nothing special...
Is that something wrong with cutter or with file?
