mutoh power up prob
martfarm
Hi all have a prob with rock 38 powering up, when you plug it in all the led flash and then go of, if you switch it on and off by its switch nothing but if you unplug it from the mains it will then make the leds flash again, started to do this after the cog on the pump to capping station came loose and jammed up hit the power off and now thats all i get all fuses tested fine any ideas thanks Martin
