Hey everyone. I am a newb. I purposely purchased an older printer to get my hands wet and learn what I can about these machines before I make a big investment.
I picked up an RJ6000 that has been converted to eco-sol. Mechanically it works. When i first turned it on and tried a nozzle check it was pretty weak but it was working, I had cmyk. but it clearly needed some help.
One of the heads was replaced in dec 2011... but before I bought it, it was sitting with ink in it for a few weeks.
What I have done so far to try and get the ink printing is:
1) checked each damper with a syringe to make sure that ink was flowing through the lines... it appears to be absolutely fine, I was able to extract ink through the dampers easily.
2) head soak (about four head soaks) also I VERY carefully and very delicately, used a syringe and some wash fluid, took the dampers out, and pushed washer fluid through the heads) As I mentioned i was EXTREMELY delicate with this to ensure I did not damage the heads/nozzles.
3) used a syringe attached to the waste lines to make sure the ink was flowing through... when I first tried it, it was definitely flowing through... but now tonight when I tried it, i'm just getting the sound of air.
after trying these things, I took one of the heads out to inspect it, it seemed to be clean so I put it back in.
Ever since I took the head out and put it back in... when I do a test print or nozzle check I get absolutely NOTHING. Before I took the head out, I at least saw ink on paper.
I am stumped and was wondering if any of you know what steps I should take next to trouble shoot the problem.
My whole goal with this machine is to LEARN how to use it, get familiar with the components and become educated, so when I make the big plunge and buy a new printer, I'll know what I'm doing (or at least be a lot farther along the road).
In the mean time, I'm really anxious to get this current printer working! so any suggestions would be very much appreciated.
