Need Help Mutoh Rj900c not turning on
theviltherapist
Hi i need help with mutoh rj900c which is not turning on after showing error e084 courent err i have checked all cables , lights on mother board ok, whenever i press power button data light just blinks and no activity it stays off
I have hold n press power button not ok
I have take all cables off the mother board and put it back nothing happnd
I have opened and cleaned capping station n pump as well
Please help,
Sent from my SM-A800F using Tapatalk
Take the memory board out of the main board and air dust the terminal. Clean the leads of the memory with 91% rubbing alcohol. Don't use anything less than 91% as it can cause damage. Let dry for about 5 minutes and reinstall. This will fix the issue in most cases. Make sure you unplug the printer and push the power button after it's unplugged and then wait 10 minutes before doing this.
