picko1967can
Hi all and thank you for my add from the Uk. I have a rockhopper 2 and a rockhopper 3 extreme.I have not had them long and brought on the cheap to give printing a go.I do use vinyl cuttig equipment.They both need work, sort of the rockhopper 2 is in very good condition for a 10yr old machine.Everything works apart from one blocked head and needs a couple of ink cartridges. My problem is with the rockhopper 3.Its been standing for some time in a cold damp unit.I've got it all warmed up and powered up.Everything lit up after I dusted all the cobwebs away and checked all the connection.I just have error E102 fuse 1 on the display.I did follow a couple of other threads on here but to no avail. After a few attempts at trying to find fuse 1 it seems ok, replaced with alternative but still no joy.There are 2 fuses per head I think, found them and checked with multi meter all ok. Can any of you kind people help me on this matter to find or tell me were or if i'm looking in the wrong place on the circuit board. Manythanks Kev
