heyskull
We have a Mutoh SC 1400D plotter.
When contour cutting small labels you can see that it is out by 0.5-1mm on the contour cut.
In the manual you can do three tests an automatic a manual and a EPOS alignment test plot.
Now when doing the automatic and manual test everything is OK but when doing the EPOS alignment test plot and you load the test sheet in you can visually see how much it is off by.
The problem is the manual does not tell you how to adjust this.
Can anyone help as I have thousands of labels to print and cannot get them to cut correctly.
SC
SC
