ProWraps
flawed take up system!
the system puts pressure on the media coming out of the printer and it creates vertical banding in the cyan prints.
i mentioned this to mutoh last year when we had 25 vans to print, all cyan. the rep said i was crazy. i have reproduced the error over and over today. and it IS a problem. with the take up bar putting tension on the media, we get vertical banding. manually activated. we dont. its instant error correction.
just a heads up to all of you running this system.
we have to leave the take up bar up, and manually activate the take up with no tension on the media.
try it. it works. hope this helps some of you.
there are other factors such as temp, etc. but if you are running the right temp/humitidy consistantly and still getting vertical banding, try it.
