[FONT="]E068 on the 1204 is the carriage / head travel that doesn't match the encoder feed back to controller.[/FONT]
[FONT="]Sensor, T-Fence, CR (Y) motor, drive belt, trailing cables that carry the signals, Main board, current draw[/FONT]
[FONT="]on power supply.[/FONT]
[FONT="]The maintenance / capping station is different than 1604s. With very little effort[/FONT]
[FONT="]it can ever so slightly rub the carriage cover - "IF" this is where error occurs [/FONT]
[FONT="]should be something closely inspected. [/FONT]
[FONT="]Clean the X drive encoder - PF disc being dirty could be causing confusion to the servo circuitry.[/FONT]
[FONT="]Note "IF" the error occurs approximately same general area of travel. Check T-Fence. Or suspect[/FONT]
[FONT="]could be the trailing cables.[/FONT]
[FONT="]If possible place in 'maintenance mode' and run the CR endurance test.[/FONT]
[FONT="] [/FONT]
[FONT="] [/FONT]
[FONT="]A few years back had a 1204 not located in this service area needed a maintenance station . After that was replaced[/FONT]
[FONT="]started having the E068 error intermittently, stopping in random spots.[/FONT]
[FONT="]Maintenance station was replaced, carriage replaced, CR motor / belt replaced, PF-motor replaced, main controller,[/FONT]
[FONT="]power supply, trailing cables. Would run for awhile then E068 would reoccur.[/FONT]
[FONT="]Seemingly replacing the main board would resolve the problem for maybe a week, then E068 right back.[/FONT]
[FONT="]Mutoh suggested that since the parts were replace one at a time possibly the course to resolving once and [/FONT]
[FONT="]for all would be to replace all suspect parts at once using a 'new' never fw updated ,main board.[/FONT]
[FONT="]After pricing out CR motor, carriage, T-fence, PF motor, power supply, trailing cables, maintenance station,[/FONT]
[FONT="]and main board best I remember the unit was scrapped/ or sent back to mutoh?[/FONT]
[FONT="] [/FONT]
[FONT="]Not that you asked but the 1204 & 1304 were a low end, low usage printer. Seemed like once they had a few[/FONT]
[FONT="]miles on them or were moved around then they weren't as reliable.[/FONT]
