Mutoh VJ-1324 head issue.
Xtreme Signs FL
Hoping someone had this issue, had to replace the printhead and ribbon cables, when installing I had the ribbons flipped by mistake so the top pins were at the bottom and bottom at top. When turning on all was good but don't print nothing, I pulled ink through printhead from caping station. I did check the 3 fuses and are there good, then I replaced them just to make sure. There are no codes, works like normal but no ink. I'm out $2000 on the printhead. Does anyone have an old printhead they be willing to let go so I can test to see if it is just the printhead, don't care if a lot of nozzles are clogged. I believe the vj-1324 and vj-1624 use same head.Thanks
jeremy print
hi i am jeremy, the Mutoh 1324 and 1624 use the same model of print head, which is DX7 print head, we sell Used Mutoh Mimaki Roland print head and printer on Alibaba, my whatsapp:+86 183 6296 5936, look forward to your reply, thanks.
Xtreme Signs FL
Yes, dampers have ink, I did pull ink through first. Everything tells me it's a blown printhead but not 100 percent sure, and to buy another new printhead without knowing that's the problem, I really need a used cheap printhead so I can test, then I will get another. Thanks
jeremy print
the good quality used DX7 head for Mutoh is around 830$
