Koala Matt
I replaced the maintenance station and dampers along with the joint going into the Y cartridge holder because it had a leak. Now none of the ink will charge. I've tried many times, both normal and little ink charge and several cleanings. I can pull ink to the head with a syringe but it starts receding immediately. No leaks or bends in the tubes anywhere.
Any suggestions? Are the new dampers no good? Should I be pulling more ink before reattaching to the dampers?
