My Edge LE beeping like a %$%^
gabagoo
I was doing quite a bit of work on my Edge LE 2 days ago and then went out for lunch. When I returned I heard this intermitant beeping and found it was the Edge acting up.
I have heard this before and was instructed to gently turn the machine on its side and open up the left side and gently make sure everything was connected and then close it up.
Well thats what I did this time too and the beeping is no longer.
I was wondering what sets it off and how does it occur?
Fred Weiss
The hamster probably fell out of the treadmill although it could just be a combination of vibration and dirty contacts.
omgsideburns
Yeah, you can get some goofy errors if any of the ribbon cables shake loose. Pull the cover off the bottom half and take a look in there.. make sure everything is plugged in.
