Need help finding any printer, that uses dye based inks (water soluble)
dreko
Hey board,
Can anyone send me info on any printer, any location... that still uses dye based inks in a wide format printer?
I need to do some water brush work on a digital print... and need it to bleed, run, etc
Ideally a 44" wide or greater printer
thanks!!
Humble PM
Mostly tolerates architects
If you have no luck, glass cleaner is kryptonite to Epson and Canon aqueous pigment ink - I believe the glycol is the killer part.
Humble PM
Yep, regular glass cleaner (forget which (UK) brand).
Or something like this would probably be pretty good at distressing the output.
