Need Help NEED HELP FINDING IP ADDRESS IN ROLAND SP 300V MENU?
dbeere
NEED HELP FINDING IP ADDRESS IN ROLAND SP 300V MENU? I HAVE NO PROBLEM FINDING IT IN NEWER MODEL ROLAND BUT THE NETWORK MENU SEEMS TO BE NON EXISTANT IN THIS MODEL, UNLESS THERE IS SOME SORT KEY SEQUENCE TO PUSH TO ENTER THAT SUB MENU???
THANKS
dbeere
HOW DO I CONNECT IT TOO VERSAWORKS WITHOUT AN IP, WHEN I GO TO ADD A PRINTER IT DOESNT APPEAR?
When you connect the printer to the computer it should install the driver in windows. Once that finishes then when you go to add a printer in Versaworks you should be able to choose a USB port and then hit verify. If everything is working right it will automatically see the SP300 and then you can set it up. You may have multiple USB ports to choose from so just select each one and hit verify until it works.
