Need Help Firmware update Mutoh Valujet 1204
NeoCortex
Hello i need help for my Mutoh VJ 1204.
i have the manual for the Firmware update and i have the firmware update.
but i need the MUTOH Maintenance Engineer Assistant
can anybody help me because my Printer says the ink not original but its an original mutoh ink and the technican say that is a problem with the firmware of the Printer
Thank you
You need the Mutoh Service Assistant not the Engineer Assistant. unfortunately I can't post that publicly but try searching for Mutoh MSA and you might have some luck.
Also, I agree with Umca. You probably either have bad cards or if no new cartridge will work, the heater junction board may be damaged.
rambo555
Thank you
Have you resolved this issue? I am having the same issue.
