islandwide
Hey folks,
I have an issue with a label file I've created print and cut on our HP Latex 315 Print & Cut system. For some reason, the die-cutter keeps trying to cut the square twice which is causing it to be torn up and rough on the edges. I thought it had to do with me using an old file and somewhow duplicating the dieline layer so I created a brand new file in InDesign. The design itself was a pdf sent from a client created in Canva - no dieline included. The new file with a single 0.25 magenta spot-coloured line called 'CutContour' continues to cut twice. Any idea why this is happening and what I can do to correct it? Can I salvage the print I made or will the solution requiring redoing?
Printer: HP Latex 315
Vinyl: 3M IJ35C-20
Cutter: HP 54 Plus
Thanks in advance,
Vinyl: 3M IJ35C-20
Cutter: HP 54 Plus
Thanks in advance,
