Sheila Case
Having some issues getting this printer up and running. Roland Soljet Pro 2 SC-540 We bought it without the heads. It had been sitting, without heads for about a year before we purchased it. We replaced the heads, caps, dampers, all 3 pumps and lines from caps to pumps. I was able to draw ink into the dampers but none at all past that point. Syringed waste tube coming out of the pump, nothing. Syringed lines between cap tops and pumps, nothing. Cap tops are still dry. Tested head board fuse and found that F2 and F4 are ok but F3 is blown. I did notice that the F2 & F3 are 72V 3.15A and F4 is 63V 3.15A , does that make a difference? It looks as if these may have been replaced prior to us buying the printer (see pic) I have ordered new fuses to (all SOC 72V T3.15A, which is what the service manual specifies). How would I also test the transistor and where on the head board will that be located? (I have also ordered new ones, just in case).
No errors after powering up (other than it's time for a wiper change, which I did but still get the "time for wiper change" error). I am able to do cleaning cycle, go through service menu, test print, everything but doesn't print anything on test print, just goes through the motions.
Service tech wants $400 min. to come to me to check it out (partly because of the area of Texas I am in), so I am determined to get this thing going myself if at all possible. Any suggestions would be most appreciated!
