gabagoo
I use the term silvering lightly here as I am not really sure what it is. Let me explain what I am doing. A client brought me a sample of an acrylic name plate that is 2" x 10" and 5/8" thick clear and either it was lasered, water jetted or flame polished. I am not sure but they are clean and smooth. I am over the year expected to do 300 of them and the plexi is all supplied. There is copy on the front and a logo on the back reverse. Pretty simple stuff. Now along the bottom edge that would be the 5/8" base there is a piece of blue vinyl which covers it and creates an illusion like all the sides are blue. Seeing that it is only 5/8 x 10" I decided to over size a piece and put it on dry. It went on fine, no bubbles and I trimmed it down. What I did see on certain angles of viewing was a form of silvering between the vinyl and the plexi. Looked like microscopic dots that created this silver ugliness. I left it overnight like a laminate thinking it will be gone in the morning but it is still there. I hit it with heat and still it is there. I ripped it off recleaned and applied the blue (saphire) this time wet, and again it was down perfect with no bubbles. This morning I still see this silvering. OK what is happening and how can I get rid of it. This is just the sample and I cant get it right. I will say that I used..gulp Avery A6 impulse blue. I can try a 3m saphire if anyone thinks it is a vinyl issue. OH I almost forgot to add this. The logo on the reverse side of the plexi that faces out forward was also cut in the impulse blue and is mostly a knockout with a basic square of blue and it is on perfect with no silvering. Can I assume that it could be the plexi edge that was cut by a third party? It is very smooth but maybe it contains micro bubbles from the process? Oh one more thing so you have all the facts here. If you hold the piece up and look from the top down to the bottom it is a perfect blue with no silvering at all. It is only seen on certain angles as light passes through the plexi, usually from the front side looking down at the piece.
