Click to Support Signs101 ...
I messed up on one of the panels that I printed in versa works. Does anyone know how to reprint just that one panel? I also need to adjust the overlap to larger but not sure if I can adjust just that one panel
If you paneled the print via clip and tile you can just right click on the panels you do not want to print to grey them out and it will only print the one panel.
Not sure you can change the overlap on just one panel. I suppose if you turned off all other panels and then changed the overlap size it might work.
Hopefully the file is still in the queue in versa.
