Hello from Phoenix :signs101:
First of all this site is great. I have been reading for the past few weeks trying to suck up as much info as I can. I am no strange to the world of vinyl signage, graphics design and electronics, however I am very new when it comes to solvent based digital printing.
I have been in the market for a used and relatively small solvent printer. I found a Falcon Jr for for a few hundred bucks that needed work and took it home. The thing fired up and went through its motions and dances with no issues except an waste bottle error which turned out to be a faulty switch. Easy fix.
As I looked under the cover, I noticed the cleaning and caping station was a mess. I took the front panel out and removed the station for cleaning using arbots acetone and butyl carbitol solution. I unclogged the lines, clean the caps replaced the wipers, inspected the pump and gears and put it back together. I pushed fluid through the cleaning lines with no problem or leaks all the way to the waste bottle.
Next came the dampers and heads. The dampers I tossed, the heads were removed and as I expected they were clogged. I used solvent, ultrasonic bath, try to push cleaning solution with a syringe, soaking, pray to print head gods, NADA!.
The lines from the carts to the dampers are not clogged. so thats a plus I guess.
All of the above sit well with me except that EPSON apparently no longer makes DX2 heads and whoever has them is taking price gouging to another level. I was lucky to score a black head from ebay for a 120 bucks or so, but the color heads are very scarce, luckily I got one yesterday for a reasonable price of 190 bucks.
Sorry just want it to tell my story and advise future newcomers of the following:
Before you buy any printer, check how much your heads cost and make sure they are still being manufactured
Now I feel better.
Just for the record I this is a side venture for me and I just needed a solvent base printer for small decals and labels NOT STICKERS!
I'll report back once I get the heads are in.
This is the path i am going to follow just from common sense and knowledge gained from the site and other reading.
Pull cleaning solution from the carts station all the way to the damper feed line for each color to flush the old ink.
Install the heads
Install the dampers and prime with ink.
Connect the dampers to manifold and fire up.
I am assuming the head rank gets entered after the machine is put back together right?
What sort of procedure should I follow before trying to print? head cleaning? alignments?
Thank in advance for the time you guys take to help others.
Now I feel better.
Install the heads
