Need Help new print head Vj 1304 , zero nozzles
Olga
Just installed a new printhead on a Mutoh 1304, replaced head cabble too and the first time I installed the head I received the dreaded e085err head heat error. I was able to clear the error by reversing cable's connectors
Now the issue seems that I can not get any color to fire on the nozzle check at all. I tried doing a little and normal charge on the ink. Ink is flowing through the print head to the capoing station and into the waste pad. I've replace the cable with the old one, still having the same problem. Replaced back the old print head- same problem, no one color on nozzle check.
Any suggestion?
