signnewbie
Hi,
I would like to share my problem with the network. We designed and printed a wrap for a box truck. Being newbies this was our first. We used Avery 1005 ez rs. Following the advice of a sign pro I met at the AC show (due to the amount of rivets) we used ClearShield liquid laminate instead of Avery"s over- laminate. We took an installer with high recommendation from a fellow SignBizzer here in NJ to install. The install date was Dec 23 2009, at that time the coldest day of this winter. The install was started indoors in a large warehouse but even with the gas heater, I think we were only in the mid 50's at best. The installer stopped after two panels and said he feels the vinyl is bad. There is almost no tackiness to it. He showed me how much tackier the masking tape is. Even warming the surface alot with the heat gun didn't help. I got the Avery rep to my shop 12/24 who claimed that the seemingly lack of tackiness is fine but is willing to test(both printed & unprinted) samples. To date I have not gotten a definitive response from him on any tests done. They were closed thru 01/04 etc. He is very quick to blame installer 1)not familiar with ez-rs 2) Did not use pre-mask. He will recommend other installer. The installer faults the vinyl. The customer is getting impatient & so are we.
My questions to you guys is: Was it 1) the cold? 2) could the ClearShield laminate (rollered on) have affected the adhesive? 3) lack of pre-mask (I don't understand how that affects tackiness?) 4)? any other suggestions?
I also would appreciate input how to light a fire under Avery at least to get some test results.
Thank you,
Sholom Hochman
Sign Here
Thank you,
Sholom Hochman
Sign Here
