No Power to Main Board
westpointsigns
I changed out the power supply on my Falcon Outdoor 62 and still have no power to the main board.
Everything is plugged in.
Power coming into the power supply.
Turn the switch on and a relay clicks that is all.
No LEDs on the main board, No LCD Screen....Nothing.
:help
tcorn1965
I changed out the power supply and still have no power to the main board.
:help
Our Mutoh has several fuses on boards, If blown we have no power. Maybe your does as well
westpointsigns
Sorry, I forgot to mention that it is a Falcon Outdoor 62 (I just revised it).
The only fuses that I know of are the Ceramic fuse on the Power Supply and the 2 fuses for the Printheads.
Any others?
tcorn1965
Any others?
I have a mutoh RIO 900. Mine has a fuse right on the main board. When we first got printer it did not power up (New), Dealer had me check fuse on main board, it was OK. Also where the cable from the power supply goes to 1st board then another connector goes from that board to the main...That was loose...re seated and had power. With him asking about fuse I assumed it had to do with power. Mine is a bigger fuse...hard to miss.
Terry
