Is it normal that I allways have a problem to install non-laminated vinyl?
Whether it is wet, dry application on glass or dry application on flat wall, vinyl always make wrinkles especially when there is a big contrast on printed graphic (some non-printed white parts and some black or dark parts). Vinyl shrinks on printed parts and this make a big problem. But this is not visible immediately after print but when installing and removing backing paper.
I tried many vinyls, not only cheap ones and it is still the same.
Sometimes I just need to make window or wall wrap which will be there just couple of months and its not necessary to laminate it. But then I have big problem to install it. I don't remember situation when it went easy.
I use Roland eco-solvent printer sp540i
Do you also have such a problems ?
