NorthControl
Hi Guys,
(First, sorry for my grammar. Im not talented in languages..)
Somebody asked me, Have I got any solution for extend the original inks expiring time.
I remember that time, when I also got this problem with original inks. Sometimes when I buy this very expensive ink bags, it dispalys: I have only 3 months left.
If you have the same problem, here is a solution in 2 words: TIME SHIFT
Since the NFC chip store the manufacture and expire dates int DD/MM/YY format, therefore it can not be change. Instead of this, we should going back in the time (not as Marty McFly did).
Basically:
1. Make an image copy from your drive, with a special backup software
2. NOTE this date, as the date of your backup made
3. Use your printer as before for the next 1 month.
4. Reload your image into the harddrive
3. Set your bios date into the next day, when you did the backup
That's all!
Here is the long, and detailed method:
1. Finish your printing jobs, and delete all ripped jobs from the printer.
2. Turn off
3. Pull out your HDD from ARIZONA
4. Put the HDD into a pc, with clone software. I bought, and used the HDClone 4.3 from Miray Software (Germany)
5. Make an image file from the ENTIRE HDD. I recommend to use the DATE in the filename too. Mandatory to know the backup date!
6. If you have the original BLUE WD hdd, it is the time to change! Buy a new PURPLE type WD HDD, or other you want!
7. Write the image to the new HDD with the software. If you have bigger capacity HDD than original, let the software to adjust the partitions automatically.
8. Put the original HDD into a safe place, and write the current DATE into it's cover. (later it can be help)
9. Put the NEW HDD into your arizona
10. Power-on, and use the printer as before (the new HDD should be working as the original!)
11. *** wait 1 month, or any time you like ***
12. Finish all your printing jobs, because all new data will be lost, when you restore from your Image file!
10. Power-off your printer
11. Pull out the HDD and take it into the PC
12. Use the same software to write back the image file into the HDD
13. Put a keyboard into the internal PC's USB port, or PS2 keyboard port (if have)
14. NO(!) put the HDD into the Arizona yet, just power-up the machine
15. On the very first screen press F2 (on 350 machine) to enter the BIOS. (Other machines maybe F12,DEL, etc... if the F2 not works)
16. Set the system date to ONE DAY LATER when you did the backup. Let the time to shows the currently time.
17. Save the BIOS settings and escape!
18. POWER-OFF the machine
19. Put the new HDD into the machine
20. Remove the keyboard.
21. Power on the machine, and enjoy!
I use this method in all my Arizona machines.
You get a lot of advantages with this trick, these are:
- You have a safety copy from your harddrive
- You can change your harddrive into a bigger - faster one
- You have extra time to use your inks
Disadvantages:
- If you should change someting in the registry in the "waiting period", it will be lost if you just simple backup later!
This means, if any changes happen in the whole system after the backup date, like: Heads timing setting, Head replace, board changes, firmware updates, SDS parameter changes, etc... all will be lost!
So, if you know, you must doing a head change for example, you should back in the time, do the head replace, and finally do a new image backup!
I hope this method would be helps a lot.
Have a nice day, and thank you for reading!
GregK
Basically:
That's all!
2. Turn off
Disadvantages:
GregK
