Click to Support Signs101 ...
I've done a few tests but haven't had much time to play around with it much - just sent down whatever file I was using and set it to overprint multiple times.
If you're trying to build up the thickness while keeping color consistency, you can use a spot/spot/cmyk profile so you lay down 2 layers of white in between each color pass. (assuming you have white)
Is there a specific effect that you're trying to achieve?
We saw a demo of texturing on the Arizona about 2 years ago. It's in the pipeline but not (natively) available yet.
I'll be seeing one of the people in the loop later this month. I'll ask about progress for you.
Ah yep I head about this one from a little birdie a few months back.
Unfortunately not much use in our workshop at this stage, but definitely an impressive piece of kit.
